I think you’ve got a number of control flow issues with your script. The actual interaction with Airtable does not use the app, it communicates directly with the Airtable API. If you are wanting Airtable to open when the script is done, you can do that - but do NOT use a CallbackURL
object - which is intended for triggering actions in other apps with will return results back to Drafts. Using CallbackURL makes Drafts wait for a response from AirTable - which is never going to get - which hangs the action framework waiting.
Instead just use app.openURL("Airtable://")
at the end of the script - or include a “Open URL” action step after the script in the action.
This is not tested, as I don’t have your DBs, but I did a quick pass simplifying your flow and removing the CallbackURL usage. Try this:
let basename = "";
let airtableURL = "airtable://";
let p = Prompt.create();
p.addButton("Add to existing record");
p.addButton("Create a new record");
if (!p.show()) {
context.cancel();
return;
switch (p.buttonPressed) {
case "Add to existing record":
// put draft in clipboard and optn Airtable app
app.setClipboard(draft.content);
app.openURL(airtableURL);
break;
case "Create a new record":
chooseBase();
break;
function chooseBase() {
p.addButton("Add to Equipment");
p.addButton("Add to Inventory");
if (!p.show()) {
context.cancel();
return;
case "Add to Equipment":
basename = "Equipment";
addRecord();
break;
case "Add to Inventory":
basename = "Inventory";
addRecord();
break;
function addRecord() {
var options = ["accessories", "apple", "bagsandcontainers", "cables", "chargers", "children", "clothes", "healthandhygiene", "luxury", "photography", "stationery", "tech", "tools"];
var selectedOptions = [];
var base = ATBase.create(basename);
var main = ATTable.create("Main", base);
var newRecord = ATRecord.create();
if (basename == "Equipment") {
let p1 = Prompt.create();
p1.addTextField("name", "Name:", "");
p1.addTextField("attachments", "Attachments:", "");
p1.addSelect("tags", "Tags:", options, selectedOptions, true);
p1.addSwitch("edc", "EDC:", false);
p1.addSwitch("purchased", "Purchased:", false);
p1.addTextField("notes", "Notes:", "");
p1.addButton("OK");
if (!p1.show()) {
context.cancel();
return;
newRecord.setFieldValue("Name", p1.fieldValues['name']);
newRecord.setFieldValue("Attachments", p1.fieldValues['attachments']);
newRecord.setFieldValue("Tags", p1.fieldValues['tags']);
newRecord.setFieldValue("EDC", p1.fieldValues['edc']);
newRecord.setFieldValue("Purchased", p1.fieldValues['purchased']);
newRecord.setFieldValue("Notes", p1.fieldValues['notes']);
} else if (basename == "Inventory") {
let p2 = Prompt.create();
p2.addTextField("name", "Name:", "");
p2.addTextField("model", "Model:", "");
p2.addTextField("purchasedate", "Purchase Date:", "DD/MM/YYYY");
p2.addTextField("purchaselocation", "Purchase Location:", "");
p2.addTextField("warranty", "Warranty:", "");
p2.addTextField("serialnumbers", "Serial Number(s):", "");
p2.addTextField("notes", "Notes:", "");
p2.addTextField("manuals", "Manual(s):", "");
p2.addButton("OK");
if (!p2.show()) {
context.cancel();
return;
newRecord.setFieldValue("Name", p2.fieldValues['name']);
newRecord.setFieldValue("Model", p2.fieldValues['model']);
newRecord.setFieldValue("Purchase Date", p2.fieldValues['purchasedate']);
newRecord.setFieldValue("Purchase Location", p2.fieldValues['purchaselocation']);
newRecord.setFieldValue("Warranty", p2.fieldValues['warranty']);
newRecord.setFieldValue("Serial Number(s)", p2.fieldValues['serialnumbers']);
newRecord.setFieldValue("Notes", p2.fieldValues['notes']);
newRecord.setFieldValue("Manual(s)", p2.fieldValues['manuals']);
main.addRecord(newRecord);
if (main.update()) {
// created record successfully
console.log("Item added to Airtable");
} else {
console.log("Airtable API call failed");
context.fail();
