CraftWork Action Group for Drafts
CraftWork - A powerful Drafts Action Group that seamlessly integrates Drafts with Craft, enabling quick capture to Daily Notes, task management, document creation, and collection workflows.
https://directory.getdrafts.com/g/22s
:sparkles: Features
Daily Notes Integration – Quickly append content from Drafts to today’s, tomorrow’s, or any selected date’s Daily Note.
Task Management – Create tasks directly in Craft’s inbox or Daily Notes, extract markdown tasks from drafts, and set schedule/deadline dates.
Document Creation – Create new Craft documents from drafts with optional folder selection, back-links to the original draft, and Daily Note links.
Collection Support – Add items to Craft collections with full property support, including text, numbers, dates, single/multi-select fields.
Smart Workflows – The “Smart Add” action intelligently detects collections in documents and offers contextual options.
Craft Documents with some more details: CraftWork Action Group for Drafts
Awesome! You rock! Thanks for doing this for us!
How do you get access to the “Full Space API”? My Craft has no such option. Just to specific docs.
Update: Duh was not on the latest craft
Ran into a problem with Create Document. It made a document with a Title only and deleted it despite it failing.
Script step completed.
HTTP.request Failed: 400, Unknown error
Content error:
Draft moved to trash
@omarshahine I’ll implement better logging and let you know when to update the group :blush: sorry for that.
Did it work before or did you never successfully create documents?
And you said, that it deleted the Document? The Action shouldn’t delete the document again once created, can you confirm this really happened?
And the Draft shouldn’t be moved to the trash if creating succeeded
It works with simple markdown.
I have a complex doc where it does not work. I will DM you a link to the content
@omarshahine I found the issue - basically the API is refusing to parse the md contents correctly that you sent me.
I implemented a workaround (and more logging).
If you reinstall the action group it should be fixed:
Getting this error
sorry, now it should work - you need to reinstall..
Awesome. Works great now. Thank you. These are awesome scripts.
Great to hear! Sorry for the inconvenience and let me know if you have further ideas
@FlohGro Great set of actions. Thank you for sharing them.
The collection action works for most of my collections, but one gives me a “Failure to create item: 400” error. I’ve tried to simplify the collection, but it keeps giving me the error. Do you have any suggestions for troubleshooting this?
@richardh Could you send me maybe a link to an empty collection that uses the same scheme (columns)?
What do you see in the action log?
@FlohGro Here is a link to the collection, and I have added the error log to the page. It’s strange; this is a very simple collection. It had a relational link and a link to a block, which I removed, yet it still creates the error.
I appreciate your help.
Without testing, I would assume that it will work if you rename the „Project Title“ column to „Title“
Will have a deeper look though
That worked! Thank you very much.
Could you please explain what happened? Why did “Project Title” generate an error?
I think I hard coded that property for the Collections so I will need to update the action group for those things.
So when no property named title is available in the collection and my actiongroup tried to add this it will fail.
I will have a look at this if I can support this generically
