I’m new to drafts and i’m trying to find a way to integrate it with craft. for example i want to dictate a fleeting thought with the drafts app and somehow have it sent to craft app. Does anyone have any shortcuts or workflows for this? i know it’d be easier if craft had open api integration, thank you ![]()
Start with a directory search for “Craft” and see if something there meets your need:
thank you very muc, I found something that solves half of my problems now I just need to find a way to see if I can write a to-do and address and have it show up as a task in the task list of craft
Back when I was using craft I often used the Export feature of notes to check what they use as content behind the features. Maybe this will help to get what you want
