Copy the clipboard from a remote device.
Action Directory link: https://actions.getdrafts.com/a/1I5
This action is handy for copying text from a remote device if you don’t have access to something like Universal Clipboard. When modifying short scripts, I find this action faster than saving to and import from the cloud.
Setup
Enter the address of the remote device in the first script step of the action.
You’ll need a simple helper script on the remote device to receive an HTTP request and return the clipboard.
If you have Python, install pyperclip
and try the following script.
#!/usr/bin/env python
PORT_NUMBER = 8080
import pyperclip
from BaseHTTPServer import BaseHTTPRequestHandler,HTTPServer
class S(BaseHTTPRequestHandler):
def do_GET(self):
self.send_response(200)
self.send_header('Content-type','text/plain')
self.end_headers()
self.wfile.write(pyperclip.paste())
HTTPServer(('', PORT_NUMBER), S).serve_forever()
