Copy as Rich Text for Shortcut to create Note
I combined two actions “Copy as Rich Text for Quick Note” then Create Note using a shortcut. I replaced [[draft]] with [[clipboard]] which creates a note with the text but loses the formatting. If I do it manually in two stages the Copy as Rich Text contain the formatting which can be pasted manually into a new note.
What do I have to do to include the formatting in my combined action?
Thanks
Ian
Worked it out - Draft action send clipboard and Shortcut gets clipboard rather than the Draft so that a Draft in Markdown is used to create a RTF formatted Note.
