Since OS Monterey I am finding that holding the trackpad and drag over text doesn’t do anything in Drafts. It doesn’t do anything at all.
Cmd+ drag over text works.
Cannot reproduce here…anyone else? Is this using an Apple trackpad (like built-in on a laptop?) Is this specific to Drafts? You are able to select this way in other apps?
Problem solved. Somehow in Apple preferences Trackpad/point-and-click/ I had ‘Look up and data detectors’ checked and it was interfering with highlight and copy.
Is there a way to mark things as solved?
