Hello, I am wondering if there exists, any visual aids to understanding the relationship between key features such as workspaces, templates, etc.? A SimpleMind brain map would be ideal.
Sounds like a novel idea. Can you share an example for another app as I don’t really get from the description what sorts of feature relationships would be presented.
If I could think of an example, I would share it. However, I’m drawing a blank. I will have to research it. Are you familiar with mind mapping apps?
Here is an example, although there are many differing ways to present the same info using a mind map.
Thank you! That’s a great start.
