I have downloaded the AI Tools that FlohGro posted, and they look great. But in order to use them you need an Open AI Account and API key. I have these, but I don’t have a subscription to Chat-GPT 4. Is there a way to modify these tools to use the free version, Chat-GPT 3?
What I want is to translate a draft from another language to English. Currently I am pasting sections of a PDF into the web Chat GPT 3, one section at a time. The translations are fine. I don’t need GPT 4. But it would be faster just to paste it all into a draft, and then have the Open AI integration chunk it up, send it to Chat GPT 3, and then past the translation into a new draft (or at the end of the current draft).
I took a quick look at this, and it looks like it’s setup to default to using the gpt-3.5-turbo model, you shouldn’t need gpt-4 access.
Do you have your billing information set up with OpenAI? It’s inexpensive, but needed. The “free” usage is almost nothing with the API. Details on set up of your API information is in the integration guide:
Revision. I’ve gotten Drafts to get a result from Chat GPT, but it soon stops translating and begins just summarising. This happened when I pasted things in manually as well.
I modified the action to say:
“Make a translation into English of exactly what this text says in its own language. Do not summarize it. Do not change its meaning.”
This seems to have fixed it.
Anyway, thanks for this. It will save me a LOT of time.
