Hi I’m trying to change from the default italic that comes up when I open a new draft. I’ve clicked on the ‘Aa’ button and change settings but I seem to always have italic. Could you direct me on this. Many thanks. Stephen
There is not explicit way to set italic as a default style in Drafts. What font are you using? It is most likely the font is missing a regular variant or something similar that is causing it to force italics.
If you switch to one of the recommended fonts are you seeing this issue?
