It is certainly possible using an action to reference the current draft’s title, permalink and date information (created/last modified). This could then be appended in some format to another (index) draft. It would be pretty straight forward to do.
What I don’t follow so much is the “storage” of notes in flags and tags. Separate drafts (notes) each have meta data. A note can be flagged or unfledged, and it can have multiple tags assigned to it. i.e. there’s only one flag option, and these are all associated with the draft, not a way of storing them. But you can set-up workspaces as a pro subscriber that allows sub-sets of drafts to be displayed based upon the tags associated with them, and the folder configuration for a workspace then determines which folders display flagged drafts.
If some more details can be set out for what the requirements would be I’m sure we could pitch in to help create something.
Just as an example, the following script would append the details to another draft with a particular ID, and write out the title and permalink as a Markdown formatted link.
//Identify the Index draft
const INDEX_DRAFT_UUID = `77947633-A441-42B6-A4C7-4E80D2D07273`;
draftIndex = Draft.find(INDEX_DRAFT_UUID);
//Add the content to the index draft
draftIndex.append(`${draft.createdAt} - [${draft.displayTitle}](${draft.permalink})`)
draftIndex.update();
However, Drafts also supports [cross-linking](https://docs.getdrafts.com/docs/drafts/cross-linking) using `[[ ]]`` notation, so using the permalink is not the prettiest option and things could probably be simplified to something like this assuming you just want to link internally within Draft, between drafts.
draftIndex.append(`${draft.createdAt} - [[${draft.displayTitle}]]`)
Then you might also want to think about formatting. Is the Index in Markdown? Do you want to force a line break on consecutively added lines (two spaces at end) or make each entry part of a bulleted list (list marker and space prefixing each line. Should new entries be appended as above, or should they be prepended at the top of the Index draft.
There’s a lot of scope to do something. Probably anything with of you would like, but getting it right is about getting the details right.
