I’m afraid this is a really basic question, but after spending considerable time trawling through the forums I’ve run into some conceptual blockage and can’t come up with the answer myself.
Simply, I want to clip text from Safari or Instapaper, and send it to Drafts with a heading/first line comprising:
- the date/time in %Y%m%d%I%m format
- prompt for a source, to be entered manually
- prompt for a subject, to be entered manually
… so the eventual draft would look like:
202001030920-james-on effort
… and I can then ping it off to Dropbox or some other archive.
Can I a) do this, and b) do this from the point at which I clip the text, or do I need to do it as part of an action enroute to Dropbox?
(And can I trigger a “send to Dropbox” Drafts action when I clip from Safari, so it all happens in one fluid movement?) Either way, how?
Suspect the answers lie in Shortcuts, but I hit the same blockage there. Any help appreciated.
