// Start a new draft
editor.new();
// Get all the "diary" drafts in the inbox
var diaryDrafts = Draft.query("", "inbox");
// Assemble
var ds = draft.processTemplate("[[date|%Y-%m-%d %H:%M %z]]");
var diaryContent = "Diary as of " + ds + "\n\n";
for (var i=0; i<diaryDrafts.length; i++) {
var stamp = diaryDrafts[i].processTemplate("[[created|%Y-%m-%d %H:%M %z]]") + "\n" + diaryDrafts[i].processTemplate("[[created_latitude]], [[created_longitude]]") + "\n" + diaryDrafts[i].processTemplate("[[tags]]") + "\n";
diaryContent += stamp + diaryDrafts[i].content + "\n\n";
diaryDrafts[i].isArchived = true;
diaryDrafts[i].update();
// Make the diary
editor.setText(diaryContent);
editor.save();
As is likely obvious to someone with more JavaScript Kung Fu than I, I’ve built some of my template into the script itself. I’d much rather call out to a template file like:
You cannot specify a date range in a query…so you would have to handle it by filtering your results. The Inbox Sweeper example action demonstrates a way to do this, but roughly:
// define the cutoff date
let cutoffDate = Date.today().addDays(-31); // 31 days ago
// query all inbox drafts
let queriedDrafts = Draft.query("", "inbox", [], [], "created", false);
// filter out any older than cutoffDate
let filteredDrafts = queriedDrafts.filter(d => d.createdAt > cutoffDate);
// now use `filteredDrafts` in your loop...
The Define Template Tag exists primarily for this need. Put one of these steps before your script step, put your template in it, and give it a name, like my-template. Then in your script, you can just make that change the line as follows:
var stamp = diaryDrafts[i].processTemplate("[[my-template]]");
I apologize for asking some more rudimentary questions, but I’m unclear as to how to rewrite Drang’s script around calling out to that template. I wonder if you wouldn’t mind amending his script with the appropriate changes; to strip out the formatting from the script and house it? I’d love some comments to help me learn what each line is doing.
var date = draft.processTemplate("[[date|%Y-%m-%d]]");
var diaryContent = "# " + date + " -- Drafts Log" + "\n\n";
var stamp = diaryDrafts[i].processTemplate("[[monthly-log]]");
diaryContent += "### " + diaryDrafts[i].content + "\n" + stamp + "\n" + "****" + "\n\n";
Something like this for the loop would work…assuming you setup the define template step as described:
// create the new templatized version for this draft...
let newContent = diaryDrafts[i].processTemplate("[[my-template]]");
// add it to the complete content...
diaryContent = diaryContent + newContent;
Minor quibble, but I would rewrite the loop without the C-style index to make it more readable, like:
for (let d of diaryDrafts) {
let newContent = d.processTemplate("[[my-template]]");
d.isArchived = true;
d.update();
editor.new();
// Assemble
let newContent = d.processTemplate("[[monthly-log]]");
d.update();
// Make the diary
let fm = FileManager.createCloud();
fm.writeString(date+" -- Drafts Log"+".md", diaryContent);
I had a similar problem that I couldn’t seem to get to work reliably, and after sending a test script to @agiletortoise , they discovered that the template tag functionality was struggling with nested tags, and said this would get fixed in a future update when this functionality was rewritten.
I avoided the problem by simply keeping the templates inside the js-script and it works perfectly. Use the new multiline strings with backticks to make it more readable and easier to maintain.
So in your case, I would just store the template at the top of the script for easy access like this:
@steinar’s answer is the correct one. The “Define Template Tag” step is for defining a value to be inserted with a template. You are trying to use it to define a template. Tags inside that value will not necessarily be evaluated because the template engine is not recursive.
Basically, a template tag should not contain more template tags.
Thank you both for chiming in. The adjustment you recommended @steinar worked perfectly, though that naturally means I see one more change I’d like to make
I’d like to adjust my final tag output, and so I’ve added something @agiletortoise helped me with previously. I’ve got the script set up thusly:
// Print tags with GitLab quick action syntax
let tags = draft.tags.map(t => `~${t}`).join(" ");
draft.setTemplateTag("formattedtags", tags);
// use [[formattedtags]] in subsequent action steps
// Declare the Final Template
let template = `#### [[title]]
[[body]]
###### [[created|%Y-%m-%dT%k-%M-%S-%z]] | [[created_latitude]],[[created_longitude]] | [[formattedtags]]
editor.new();
// Assemble
var diaryContent = "## " + date + " -- Drafts Log" + "\n\n";
let newContent = d.processTemplate(template);
d.update();
// Make the diary
and instead of the tags themselves, I’m getting [[formattedtags]] in my output.
Template tags are specific to a draft. You are setting the custom tag on the draft, but then processing the template on a different draft (the d variable). I think you actually want the tags to be derived from each individual draft you are looping over as well…so move that to the loop, like:
let tags = d.tags.map(t => `~${t}`).join(" ");
d.setTemplateTag("formattedtags", tags);
d.update();
