Hi,
I created a drafts Action to Add markdown formatted Urls “title” to DEVONthink / DTTG as a bookmark.
It will scan the current draft for all available markdown links and prompt you to select the one you want to bookmark.
If there is only one url in the draft, it will be used directly without a prompt.
Download here: https://actions.getdrafts.com/a/18n
Hi, this action doesn’t work for me. Tried both on draft with 1 md link and several md links. DEVONthink opens, but nothing more happens.
can you share an example draft with the links you provided? also does the Drafts app show a notification?
Which version of DTTG/DT are you running?
And are you talking about running the action on the mac or iOS?
I tried on different drafts, so don’t think it is something wrong with drafts itself.
Here is example I used today:
# Test
[Bookmark markdown URLs to DEVONthink - Actions - Share What You've Made - Drafts Community](https://forums.getdrafts.com/t/bookmark-markdown-urls-to-devonthink/7442/4)
After I run the action, DEVONthink opens and nothing more. Few minutes later (maybe 2-3) I get error from Drafts: Failed
Message is: undefined, Script step completed.
DraftsVersion 26.1.5
DEVONthink Version 3.6.3 Pro
I haven’t tried this action on iOS because I do mostly my clean up in Drafts inbox from a MacBook.
please update the action, I fixed the issue in the directory.
I had the same problem fixed in my local copy of the action.
sorry for that
Thank you! it works now
