I’m working on an action that will allow me to type a simple concept or idea into a draft and then have the action;
- copy that draft to the [[clipboard]]
- replace the entire content of the draft with inserted text having the [[clipboard]] somewhere in the middle of all the new text
I’m having a problem figuring out how to script the ‘clearing out’ of the draft before I ‘Insert Text’.
Can anyone point me to an existing action that uses this type of script component?
Thanks in advance
Not sure if I have got the right picture, but perhaps assign a new value to ‘draft.content’ (built as a sandwich of three layers) ?
try {
'use strict';
const strThought = draft.content;
draft.content = [
'Prefixed material,',
strThought,
'and appended material.'
].join('\n\n');
draft.update();
} catch (e) {
alert(
['line', 'column', 'message']
.reduce((a, k) => a + k + ': ' + e[k] + '\n', '')
This would be a little simpler, I think:
let template = `
Text to insert before
[[draft]]
Text to insert after
draft.content = draft.processTemplate(template);
draft.update();
This is using Drafts template and tags to build a new text with the contents of the current draft ([[draft]]) in the middle.
( and in this case, of course, JS’s own text expansion is also an option )
draft.content =`
${draft.content}
draft.update();
I went with your suggestion for using the template method and it works like a charm.
I’ve posted a generic version of what will soon become one of my most used actions.
Thanks
