Hi all
Since now there are actions in the new Betas for macOS, I was wondering if bash or AppleScript scripts will be possible on the Mac desktop actions?
thanks a lot
Z
Hi all
thanks a lot
Z
I queried that on the Slack group recently. There are some sandboxing challenges in using scripts that need to be looked at if this is to be included. It won’t be in the initial actions options.
thx a lot for the info!
Update: For anyone coming across this, version 19 introduces AppleScript and script support ![]()
thx!
will look into it!
