Basecamp integration
Basecamp is a project management app. Is it possible to integrate it with the drafts app?
Check out the Basecamp API documentation. You would need to build out your desired functionality based on that.
Thanks for the revert.
Not sure what sort of integration you were looking for…if you just want something simple to get content into Basecamp, you can email to Basecamp, which should work fine with email actions in Drafts.
More or less exactly what I needed! Thanks.
