In Share modal on iPad, auto-match works, but on iPhone it doesn’t.
I tried turning auto-match off, closing app, turning it back on, still same.
On latest / store version v27.0
Works here…are you using the same syntax default for the Share extension on both platforms? Have checked that the setting is enabled for that syntax in editor preference?
Ah, found the options for the Share extension, in settings, never used that before – thanks
