Hello, is there a way of importing all my calendar events for tomorrow and append it to the current draft?
TIA
TIA
Thanks. Is there a way to tweak the script so it automatically gets all the calendars?
(And also so it defaults to tomorrow without having to use a date picker?)
I would look at using getAllCalendars()
then looping over the array of returned calendars and grabbing their events.
If I was amending the action to work with all calendars, I would simply remove the prompt and set it to use tomorrow’s date rather than the result of the prompt input. Once you make some changes to that generic action, I figure you may as well configure it to meet your exact use case.
