Hello,
I’m wondering if anyone has insight as to whether Drafts to Standard Notes actions could be created?
I see that I can use the share sheet and send a Draft to Standard Notes, but what I’d love to be able to do is append a note to the last open note in SN, or append to a journal file I have in SN. I am thinking that this may not be possible due to SN’s encryption, but would appreciate any thoughts or ideas.
Standard Notes does not have a URL scheme or Shortcuts support; so no automation options beyond the share sheet it seems.
Best you can get is probably get for your use case is copying text to the clipboard and launching the app so you can then select and paste your content.
Thanks. Appreciate the reply.
