Is there a action to strip all markdown tags and only keep text?
See my suggestion/approach/action in this post from last month.
thanks…if i just want to replace the original text with the plaintext, how can i change the action. sorry for knowing nothing about coding.
Okay see how close this gets you. It isn’t a perfect stripping, but maybe it will be good enough? If not, it could be built upon to deal with additional cases through judicious find and replace steps following this initial conversion.
Note, I’ve set it to save a version before it updates the draft so you can return to it in your version history.
Thank you a lot. It works. This make me much easier to handle my html files.
Actually I googled this before, all are online tools, need upload and download, happy to use this function in Drafts.
