I use transcription a lot for text input and capture and then refine it in a separate AI ‘rewriting’ app with a specific prompt to remove non words and repetitions and punctuate in short sentences and paragraphs.
Dictated text is often the opposite of this! And the transcription accuracy that Drafts can achieve using the Apple inbuilt system is OK rather than good.
Is there a Drafts action which can do this kind of AI clean up edit, perhaps making use of my OpenAI or Anthropic account and API?
What has worked well for others who may use a similar workflow?
