I use the Split at delimiter action, created by @nahumck, quite a bit. But I have two requests:
First, my original draft usually has tags, because I often work in a specific workspace. How do I modify the action to make sure the newly created drafts carry the same tags as the original, so they all appear in the same workspace?
Second, the action works from beginning to end, so if the body of the original draft contains:
“A|B|C”
the new drafts appear in reverse order in my folder:
C
B
A
Original draft
Is it possible to modify the action to split the new drafts off starting with the last occurrence of the delimiter first?
This may seem trivial, but it’s a pain in the butt to work with several drafts, each with an action item, in reverse order in my folder.
By the way, thanks to Nahumck for your wonderful contributions to the Drafts actions directory!
