jaymf
September 8, 2025, 10:21am
1
I have an action group called Markdown.
In it I have Redo and Undo.
Redo and Undo are showing on the iPhone in the action bar.
But they are not showing in the action bar or the action group on the desktop when a Draft is loaded.
Redo and Undo are showing in the “Manage Actions” menu, however.
Any idea why the conflict?
Edit action. Scroll down. Check the visibility settings. You can set visibility for both groups AND individual actions. Options are for list, action bar and search for iOS and Mac separately.
If those options are set appropriately and you’re still not seeing your actions where you’d expect, holler!
jaymf
September 8, 2025, 12:09pm
3
Thanks - yes all those settings are correct on my end:
sylumer
September 8, 2025, 12:30pm
4
Those are the group settings. Are the action settings good too?
jaymf
September 8, 2025, 1:53pm
5
That was the issue @sylumer – did not realize I had that granular control for each action.
Resolved - many thanks!
LMAO— it was the settings for individual actions that I was pointing towards! Glad you got it sorted.
jaymf
September 8, 2025, 3:04pm
7
Oh damn - sorry I missed that. Grateful for your quick reply and response, and always all of your help.
