Hi, Just wondering if there’s an action that i can create or import where i can select a text and trim white space not just beginning and the end.
Thanks for the Help.
Maybe “TAD-Compress Spaces and Lines” in that group is what you want?
It is a little hard to understand exactly what is required as “trim” is explicitly focused on trimming ends. I’m not 100% clear on how trimming in the middle might work.
I could see it being a compression as above, but I could also see it being taking lines in the selection and trimming each line independently.
