Whisper Flow on Drafts - Activation of keyboard not working
I am trying to activate the Whisper Flow keyboard in Drafts - without success.
Alternatively, I have tried to use the keyboard with Apple Notes, which is working. Is there any reason why the keyboard would not operate in Drafts? It certainly does not work when you use the Apple magic keyboard or some other Bluetooth connected external keyboard, but it does work or better to say it should work when you use the internal iPad keyboard. I appreciate any support, help or ideas with this. Thank you.
I recently signed up with Wispr Flow for a year and have been quite pleased with it so far. I use it both on my Windows Surface Pro X laptop and on my iPhone 13 Mini. I have no trouble using Wispr Pro on both.
Is it possible that you have not yet fully installed the Wispr Pro keyboard in the settings on either your iPhone or iPad? Clearly, you’re attempting to use an iPad., iPhone, or Mac since you are using Apple Notes. I use Wispr Pro with either an iPhone, iPad, or a Mac device.
I did find that I had improperly installed the Wispr Pro keyboard on my iPad, and to fix this I had to re install Wispr Flow through the keyboard setting found in “Settings, General”. This worked and I was able to get Wispr Pro working - quite well actually.
