I’ve gotten the Todoist integration to work and everything appears to be working fine except for Todoist recognizing the project following a #.
For example when I type “Respond to Ben’s email tomorrow #work” Todoist accepts the “tomorrow” input but leaves the task in the inbox and doesn’t assign it to the “work” project. I’ve made sure I’m using the correct letter case.
I wrote the Todoist V3 action. I’ve just tested it again and it’s definitely working for me. The case of the project name doesn’t seem to be significant (I used ‘#work’ in the line, but my project is actually called ‘Work’.
I don’t think the Todoist Quick Add API will create the project if it doesn’t exist, but if you have the project in place already it should be fine.
UPDATE: Installed it on my iPad and all is well. The dialog to select the action group did not come up on my iPhone for some reason (or I was half-asleep and missed it)!
Was:
Call me a noob, but I can’t see where the action ends up after clicking ‘Install’. Do I need to create an action and call it in a step?
