I am using @davenicholls outstanding Todoist v3 script. I want to take it one step further. I would like to take a draft with a List and import into Todoist. To do this I would like to take the draft that has the List, convert the List from “# Test” to “#Test” and then run the Todoist script. Problem is my Java script skills are weak and I don’t understand how to do this. I appreciate all the help@
I think this would be all you need.
draft.content = draft.content.replace("# Test", "#Test");
draft.update();
Hi,
I’m not quite sure what you’re asking.
Are you saying that instead of using:
#Test
To set a default project, you want to be able to use a header. i.e:
# Test
but still have it picked up properly?
If so, if you look in the script you’ll find a line:
`var proj = line.match(/^#(\S+)\s*/m);a
I haven’t tested it, but I think if you add a space as follows it will do what you want:
var proj = line.match(/^# (\S+)\s*/m);
If you change it to:
var proj = line.match(/^# ?(\S+)\s*/m);
It should match either format.
Dave
Perfect! Thanks ! Now I can create lists and send them to Todoist
