Tap and hold "+" for new draft options
tip
dictation
import
#1
If you tap and hold on the “+” button when creating a new draft, Drafts will offer a number of options to let you pre-fill your new draft:
  • New with Clipboard: Creates the new draft with the current contents of the system clipboard.
  • New with Selection Create a new drafts using the current text selection from another draft. Great for splitting off some text from a longer draft.
  • Dictate: Opens Drafts custom dictation interface, ready to accept dictation.
  • Import File: Opens the system Files.app file browser to import text files from any Files app source (iCloud, Dropbox or other services with document provider integration).
