Syntax export not working in 51 or 52?
I’m trying to export the MultiMarkdown syntax so that I can add a couple additional features. But after right clicking on the syntax and selecting “Export…” either (a) nothing happens, or (b) Drafts crashes. I’ve submitted the crash reports when they come up.
Version: 52.0 (805) * E:legacy
OS: macOS Version 26.5 (Build 25F71)
9210547C-501A-4EFA-8F22-3137839A434E
Pretty sure this is fixed in the 52.0.1 release I just posted (like, literally just posted, may not be showing up yet, but should shortly)
Thanks. I’ve updated (and restarted my Mac for good measure) but the problem persists. I just get a system beep after choosing Export… but nothing more. (No crash yet though either)
FYI - the issue was that I was attempting to export the syntaxes when in the “Editing” tab of the Editor settings. Right clicking gives the option to export, but results in an error beep and nothing happening.
Doing the same when in the “Syntaxes” section of Editor Settings has the correct result.
Ok, got it. Sorry, had been working on the other issue and assumed it was related. Will fix.
No worries at all—doesn’t need to be a priority since there’s a work-around. I just posted to make sure any other users who encountered the issue found the solution as well.
