Stop x-callback
I have an action that runs a Workflow in the Workflow app. After it runs the action it currently returns to Drafts after. How do I stop this happening? I have it set to trash the draft after running the action - is this causing my issue? If it is - is there a way to trash the Draft and then run the Workflow without having to return to Drafts?
Try using a URL action rather than a Callback URL action.
This just runs a Workflow called TestAlert. It does not return to Drafts afterwards.
I’m using Shortcuts and am using the Run Shortcut action. Not sure if that makes a difference.
Oh. You said Workflow above.
You would just change the URL from workflow to shortcuts:
shortcuts://run-workflow?name=TestAlert
You would of course also specify any input you are passing across as per the URL scheme (same as Workflow as far as I know right now). e.g.
shortcuts://run-workflow?name=TestAlert&input=text&text=[[draft]]
So the only difference is in the identifier at the start of the URL.
Great thanks. I have it working., Instead of using the default Shortcut action step I manually put in the URL using the URL action step as per your suggestion.
