Is there an elegant solution for this yet? I’m experimenting with a Slack app connection but lack the programming/scripting knowledge to make it work properly.
Have you found an answer to this yet? I just re-discovered Drafts and am kicking the tires on the desktop version. The first thing I thought to do was use it to send a Slack message. Save putting it into the clipboard I’m not sure what else I can do.
Slack has a share extension on iOS. You can use it with the “Share” action in Drafts to send to channels or as a DM. There’s no direct integration, and the Slack app does not seem to offer the same system share integration on Mac.
