Reset Editor to Default
Hello,
I’ve been spending more time customizing the editor in Drafts and noticed that there doesn’t appear to be a quick way to reset editor settings (font, size, line height, margins, etc.) back to their defaults.
It would be helpful to have a simple “Reset to Defaults” option for the editor. This would make it easier to experiment with different setups without worrying about manually reverting each setting.
I imagine this could be especially useful for users who:
  • frequently tweak their writing environment
  • want to quickly return to a clean baseline
  • may not remember the original default values
Curious if this has been considered or if there are any constraints that make this difficult to implement.
Appreciate all the thought that goes into Drafts.
Thank you!
Johnny
Not really something that’s come up, but I’ll think about it. I don’t know how much sense it makes, because there are no real preferred defaults, and if there were they would probably need to be syntax-specific.
Do you really make frequent changes? I think most people settle on their basic preferences and only make minor changes now and then, in particular contexts, like bumping up or down the font size or toggling paragraph numbers on or off.
Hello again, and thank you for the response. I’ve been experimenting with even more fonts recently, and you’re right… I haven’t wanted to “revert to default” as much as I thought. Appreciate your consideration!
