Hi,
I have this line of Javscript:
draft.content = draft.processTemplate("[[line|..7]]")
I want to replace the „7“ with a number that the Action asks before running (using 7 as default answer).
Can anybody help me with that, would be awesome, thanks a lot.
You want the input to be something you type each time, or is it always going to be an a range where it’s easier to hit a button (e.g. is it always going to be 3,4,5,6, or 7)?
This is the script to create and show a simple prompt with one text input (modified from example in docs):
let p = new Prompt();
p.title = "Number of Lines";
p.message = "Enter number of lines";
p.addTextField("noLines", "Lines", "7");
p.addButton("Continue");
if (p.show()) {
// retrieve value from prompt
let noLines = p.fieldValues["noLines"]; // this is now "7", or whatever you entered
// now build a template with that value
let template = `[[line|..${noLines}]]`;
// apply the template, per your above
draft.content = draft.processTemplate(template);
I would even write this to get the number keyboard and ease the typing:
p.addTextField(“noLines”, “Lines”, “7”, {“keyboard”:“numberPad”});
