Hi!
When taking notes on stuff I read, I use a template that looks something like this
YMDHM The title
title: The title
tags: #inbox #andperhapssomeothertag
source: URL
timestamp: YMDHM
My note, often with some
> markdown quotes
The reason for Title being duplicates on the first two lines (and with a time stamp in the first) is that I use the title + time stamp as filename when saving to Dropbox.
Now, my question is how I most easily create a note like this in Drafts. For notes I take when reading a book or a newspaper, I’ve a TextExpander snippet with the template. But I also do a lot of reading in my RSS reader and in Pocket - and I suspect things could Ben automated quite a bit using the apps’ share extension as a starting point, and then selecting Drafts.
The problem is that the content in the new draft is not based on my wanted template. Sharing from Pocket, as a example, creates a draft like this:
http://getdrafts.com/
Drafts. Where Text Starts.
That is, the source URL on line 1 and the article’s title on line 2 (which, by the way, is not the title I want to use in my note - where I want to use a title of my own thoughts, not the source). And, if there is something I want to quote, I’ve copied it before I press Share and paste it on line 3 and onwards and also add my own thoughts.
Now - what’s the easiest way to go from (input)
The Title
> Some quotes text that might or might not span more then a line.
Followed by my own notes one one or more lines.
to (output)
YMDHM The title
title: The title
source: URL
timestamp: YMDHM
All notes created will have the #inbox tag, and in some cases I add more. The time stamp should be created automatically, based on date and the current time. The Title I add manually at some step in the process and have that duplicate at both the first and second line of the output draft.
What I have in mind is a solution where I switch to Drafts and have a script that takes the input, parse it and creates the output. But I have no idea on how to do this. Any suggestions? Even better if this script could be executed from the Share sheet so I don’t have to switch to Drafts and back to Pocket to continue to read.
This is way beyond what I ever have done with Drafts so any help are appreciated!
