Need help figuring out what to remove from Action Share Parsed Template so that instead of emailing the action can update the draft with filled-in content.
I know there is Insert Text action that can be built from scratch but for long text drafts it may be easier to parse a draft rather than create/modify Insert Text with Prompt action.
Edit: Through trial and error I figured a few things out but not sure that I am doing the right thing.
- To update the existing draft, add this at the end of the Parse Script Action
// Update content draft.content = draft.processTemplate("[[parsed_draft]]"); draft.update("[[parsed_draft]]");
- To create a new Draft from an existing draft, add this at the end of the Parse Script Action:
// Create a new draft from existing
var d = Draft.create();
d.content = draft.processTemplate("[[parsed_draft]]");
d.update();
editor.load(d);
draft = d;
Questions
Q1. Where does the “parsed_draft” come from. I can’t find it in the original script anywhere.
Q2. How can I connect this script to an existing draft template so that it turns into a single action:
- Use New Draft with Template to choose a template.
- Run Parse Template to parse the draft for variable.
All in one action.
