I want the action to copy what I’ve made in drafts and open in in Noted. There is an existing notebook called Inbox I want it to create the new note in using the first like as the note title.
I’ve tried making one and I can get it to do everything but copy the Tex in to the new note.
I made a callback action noted://new-note?title=New%20Note¬ebook-title=Inbox&title[[title]]&text=[[body]]-notebook=true but as mentioned won’t add the Tex in from drafts just creates a new note called new note in my inbox notebook
The Noted documentation says nothing about being able to put text into the body of a Noted note through the URL scheme. I tried a few things, hoping for undocumented behavior, but nothing worked.
The best I think you can do is use a two-step Action. First step: put the body of the draft onto the clipboard. Second step: launch a URL that creates a new note with the appropriate title in the Inbox notebook. After running the Action, you’ll be in Noted and can paste the clipboard into the body of the new note.
