Newbie here,
Simple use case, however cannot seem to be able to make it work. Simply put, I want to append some text (prompt user input) to the beginning of the [[title]] only.
Not sure how to do this. For example, in this case I just want to add a β-β to the beginning of the title
This is my sample note -->> -This is my sample note
If you have tried a particular way, it is worth posting what you have. Sometimes it will just be a pointer in the right direction to get what you have already to work.
