I just updated to the new latest New Draft with Template action and when I run it, I see this error:
No templates found. To make templates available to this action, create a draft with the template content and assign it the tag "template".
None of my previous drafts marked with the tag template have changed. Using the old version works for me. Anyone else seeing this issue?
Looks like a bug in that the alert warning you about not finding any matching templates was still hard-coded to use “template”, even if the configuration of the action is different. I just updated it to fix that - but you can propably just right-click it and check what tag is configured for the action to use. I’m betting it’s not “template”
Thanks! When I check the configuration, it says Template tag as template. I updated to your latest fix and now it says undefined as the tag in the error.
I finally got it working. I guess I needed to press Save instead of Cancel in the Configure Action even though template was already listed as the Template Tag. Anyway, glad it’s working again for me!
Weird. Maybe there was a space or invisible character in there accidentally? Not sure. I was not able to get it to fail in my testing.
Yeah I was stumped too. I also checked for a space at the end but it was just template. It’s almost like it wanted me to force configure it.
