The Title tools works when the text to be “titled” is lowercase, but it does not work when all the letters are in uppercase.
Can someone modify the Title tool so it also converts ALL UPPERCASE text?
Thanks,
Howard
Thanks,
Howard
Try lowercase first and then title.
Reinstall the Title action from the directory and replace the one you have. This one was updated to lowercase first several months back.
Thanks for the info. Now the script does exactly what I need.
