Hello
Is it possible to use the Drafts Quick Capture feature to Automatically Capture to an existing note? I want to add it to a note called Drafts Quick Capture
At the moment, when I use it it creates a new note each time.
Thank you
Amit
Hello
Thank you
Amit
Appending and pretending in the capture window is a Drafts Pro feature:
“Appending and pretending”.
Another one bit by this piece of autocorrect.
Feeds my imposter syndrome.
Yikes that was a embarrassing typo Typing on phones really is unreliable I guess.
Thanks very much for your replies!
Watch out for those typos!
