I have an ongoing issue with really long links like the example below. This is running a query in another app but Drafts seems to stop somewhere part way through the link instead of pulling the whole thing.
accord://search/ESVS?day*_[RANGE_Is._2:2,_11–12,_17,_20;_3:7,_18;_4:1–2;_5:30;_7:18,_20–21,_23;_10:20,_27;_11:10–11;_12:1,_4;_13:6,_9,_13;_17:4,_7,_9;_19:16,_18–19,_21,_23–24;_20:6;_22:5,_8,_12,_20,_25;_23:15;_24:21;_25:9;_26:1;_27:1–2,_6,_12–13;_28:5;_29:18;_30:23;_31:7;_34:8;_39:6;_52:6;61:2]
Separately, could we get this url scheme whitelisted? More background for the scheme in the second link if that’s needed.
logosres:ESV;ref=Bible.Eph.3.6
https://community.logos.com/forums/t/172671.aspx?PageIndex=2
I’m not counting the characters but maybe this URL hit a 256 character (or whatever) limit.
In other words seems like a badly-structured API.
Interesting thought. It’s stopping at 137 characters. In case this makes running it down easier, immediately after this string - “ 13:6,_9,_13”
Can you copy and paste the URL below and give it a try to see if it works?
accord://search/ESVS?day*_[RANGE_Is._2:2,_11-12,_17,_20;_3:7,_18;_4:1-2;_5:30;_7:18,_20-21,_23;_10:20,_27;_11:10-11;_12:1,_4;_13:6,_9,_13;_17:4,_7,_9;_19:16,_18-19,_21,_23-24;_20:6;_22:5,_8,_12,_20,_25;_23:15;_24:21;_25:9;_26:1;_27:1-2,_6,_12-13;_28:5;_29:18;_30:23;_31:7;_34:8;_39:6;_52:6;61:2]
Woah. That worked. What did you do? I’m sitting here staring at the two URLs trying to find the difference.
Excited! Thanks!
Your original URL uses at least one “–
” rather than “-
”. They may look the same in certain circumstances, but they are entirely different characters.
The character is known as an en-dash. It’s supposed to be used syntactically for spreads of ranges. It’s a bit longer than a dash/hyphen, but shorter than an em-dash. That can make it a bit hard to distinguish visually from the others depending upon where you are viewing it.
You can view some of the technical details here:
http://www.ltg.ed.ac.uk/~richard/utf-8.cgi?input=–&mode=char
