Hello,
Ideally, I would like a script that would load the ‘Default’ workspace, and select the ‘inbox’ or the ‘flagged’ tab (based on a conditional statement).
I can’t work out how to load the ‘Default’ workspace, so I have created a ‘Drafts’ workspace, which I can apply like this:
let workspace = Workspace.find(“Drafts”);
app.applyWorkspace(workspace);
However, I don’t know how to load the ‘Inbox’ tab, or the ‘Flagged’ tab. Does anyone know? I want to load different tabs depending on the action.
Thanks,
Andy
Couple of notes:
If you create a new Workspace
object, it is configured like your default workspace. So let workspace = new Workspace()
will get you the default workspace.
Workspaces can select a folder when applied. So, if you want to programmatically select which to apply, you can set the loadFolder
property of the workspace object before applying it.
So, something like:
let workspace = new Workspace();
if (wantsFlagged) { // whatever your logic for choosing folder is here...
workspace.loadFolder = "flagged";
else {
workspace.loadFolder = "inbox";
