Under the File Menu there is an item Next Draft. It shows the Symbols: for Control-Tab (⌃⇥). I cannot get this to work in my context.
My Context:
I am in the search window and I type enough to reduce the hits to the single note that I want. If I go to the File menu and select Next Draft, I get the behavior I want. The single found item in the sidebar is highlighted and its content is shown in the main text window. However, if I type Control-Tab it seems to be overridden by an App selector window.
How can I, simply from the keyboard, select the top “search hit” shown in the sidebar?
Thanks. I am new to Drafts.
The default system shortcut for the app switcher is ⌘-tab
, not control-tab
…so you have that remapped on your system? It should work. You have a few options:
- If you hit
tab
to unfocus the search field, you can then use up-down arrow keys to select drafts in the list. - You can remap “Next Draft” to something else with an application-specific shortcut in System Preferences > Keyboard so that it does not conflict with your app switcher assignment.
- You can remap the system app switcher back to
⌘-tab
so that it doesn’t conflict with the drafts shortcut.
- Your suggestion to hit
tab
and theup-down arrows
works for my needs so - It was Keyboard Maestro rather than some System Preference that had hijacked the shortcut:
control-tab
. I just never had run into this. I guess I never hitcontrol-tab
before. - When I disabled this Keyboard Maestro shortcut, which apparently is enabled by default, then things worked as expected.
- Your very rapid response is appreciated so you have earned a new customer, and I am upgrading to the “pro” version.
Another minor tip, if you arrow up-down to select your draft, you can then use ⌘-enter
to focus the editor for editing.
That I had figured out
