Insert Local Image Reference example
It works now! Your script showed a space after the previews folder name and then I went and changed the folder from “Images” to “images”.
Thank you for that script and thank you for sticking with me on this!!! I can finally generate class notes from Drafts!!!
No problem and glad we were able to get it all figured out and fixed.:+1:t2:
This is a lovely script.
That is really helpful and easy to use and share!
Thanks.
This action works lovely. Thanks!
