I’ve installed this action from the directory:
https://actions.getdrafts.com/a/1VE
It sends the draft to Ulysses as a new sheet.
I want to adapt it so that it uses a template tag, defined in the step before the script. Currently it just sends the raw draft.
For reference, my template tag is [[allofit]] and the template:
# [[title]]
[[body]]
The end result I’d like is that the first line of the draft will have markdown for H1, followed by the remainder of the body of the draft.
I’ve tried a few things that haven’t worked, but my knowledge of javascript is very limited.
Thank you for your help.
