I am using the Monthly Journal to create a journal. However, rather than save my entries in Drafts I would like to save them in a folder in iCloud Drive. Currently I wait until the end of each month and then run an action to save the Draft containing the last month’s entries to a file in iCloud Drive. However, I would prefer that each time I made an entry that it is saved direct to a file, and I cannot work out how to do this?
If it is just a string of entries I could just create an action using the File step to just append the entry to a file. However, the first line of the file has the Month title, and so I am using the script in the action above to create the running draft, but I get stuck on saving the updated draft to a file.
