am1n0
March 31, 2019, 8:43pm
#1
I did not find the function in the application Drafts for mac version. In the iOS it is. How to merge notes?
That’s literally just been released.
Drafts 5.9 (macOS) is now available in the Mac App Store , details below.
What’s New
New: “Tag > Add…” and “Tag > Remove…” commands to bulk assign or remove tags from selected drafts. Available both in File menu and context menu of draft list.
New: “Merge…” command to merge multiple selected drafts. Available both in File menu and context menu of draft list.
New: Rename and Delete tag commands in context menu of tags in the filter list.
New: “Correct spelling automatically” editor setting t…
Hi! For some reason, the merge function doesn’t work for me on MacOSX. What are some reasons for why this might happen? I hear a chime and nothing happens…Sorry, a newbie here!
Can you describe exactly what you are doing? How many drafts are selected, what you do to trigger the merge, etc.
