The action for sending to a new Ulysses sheet works fantastically, however for short pieces of text I often need to paste them into existing Ulysses sheets and copying them doesn’t generate the correct formatting.
Is there a way I can modify the copy action to convert the markdown to the right type for copying into Ulysses?
This one is on Ulysses end. Drafts does not alter the text it puts in the clipboard, but for some reason Ulysses does when you paste. I discuss this with them a while back, and I believe they had a reason for doing it, but I honestly don’t remember what it was. You might open a ticket with their support asking for details.
