This is my first time using Drafts so I apologize if this has been discussed in the past.
Is it possible to collapse links so when you’re not editing them, it doesn’t show the link. Often, with very long links, it can be distracting.
I’ve attached an example from an app called Folding Text (https://www.foldingtext.com/). The first screenshot is when you’re not editing the link and the second is while the cursor is inside of the link. I know Bear and Ulysses does something similar.
It’s pretty straight forward (one step no scripting) to create an action to open a selected URL. Selecting a URL is typically through a double tap/and maybe triple click on Mac (not at mine right now and I forget).
