This is literally the first script I have ever put together in Java script. The idea is taken from the Add to List action in the directory, but instead of picking which one, I wanted to add it to a specific draft everytime, without having to find that draft to update it.
I consider myself an automator, not a programmer. And using URL schemes this would have been super easy for me, but as a learning experience I did it this way.
I’m sure it could be improved though so please tell me how.
[https://actions.getdrafts.com/a/1Ig](http://Add to Draft)
const template = `
const currentContent = draft.content.trim();
// replace the UUID here with the UUID you want to append too.
var d = Draft.find('99D8294B-192D-465F-BBBD-AC29EAFAC6D6');
d.content = d.content + currentContent + template;
d.update();
Looks good.
I don’t know if you would like to handle the case where the UUID isn’t found, but if you experiment with a string that isn’t a well-formed UUID, or doesn’t match any local Draft, then you can confirm that an expression like:
alert(typeof strUUID)
reveals Draft.find() to return the special value undefined
when a UUID string is not found.
That leads to various ways of producing a heads-up when no match is found.
If, for example, you start by giving the UUID a name:
const strUUID = '99D8294B-192D-465F-BBBD-AC29EAFAC6D6';
you can check whether a matching Draft has actually been found, and branch on that condition.
For example, something like:
if (typeof d !== 'undefined') {
d.update();
} else {
alert(`UUID not found:\n\n${strUUID}`)
Looks great!
Not sure if you have any need for this tip, but if you did want the appending to have some additional information like a timestamp, you can use Drafts’ template engine in a script as well. Something like:
const template = `[[date]]
[[draft]]
d.content = d.content + draft.processTemplate(template);
d.update();
I guess in my head the existing UUID would always be there because the intent was someone would make a draft first of something they want to be a running list.
